cam position sensor
Old Oct 14, 2006 | 07:37 PM
duckslayer54665's Avatar
duckslayer54665
Default cam position sensor
Hello I need some help. I have a 1999 dodge ram 5.9L 4wd. And every now and then it wont start like it aint getting no fire. But if I keep trying it will usually fire up. And the check engine light comes on. I reset the computer the light goes off and the truck is uslally good for about a week. I used my friends scaner the other day. And it came up cam position sensor. I called the local parts store and they dint have one list for dodge. Is this my problem???
Old Oct 14, 2006 | 07:42 PM
bamory's Avatar
bamory
Default RE: cam position sensor
Was that the Crank position sensor?
Old Oct 14, 2006 | 07:46 PM
duckslayer54665
The scanner said Cam position sensor.
Old Oct 14, 2006 | 08:09 PM
Ramdamit98's Avatar
Ramdamit98
The Cam position sensor is under the distibutor cap on V-6 and V-8 engines. If it helps here's an image of it.
[IMG]local://upfiles/32197/3DA93A76716D42669C4F6C58D35B7B04.jpg[/IMG]
Old Oct 14, 2006 | 10:36 PM
bamory's Avatar
bamory
Easy fix but just never heard of one going bad. Any other codes along with that one?
Old Oct 15, 2006 | 04:31 AM
Scottr1110's Avatar
Scottr1110
i had that one happen to i dont remember any other codes with it
Old Oct 15, 2006 | 12:15 PM
steve05ram360's Avatar
steve05ram360
it is a hall effect sensor, just like the rear diff sensor and the crank sensor.
you could have a pinched wire, yank your distributor cap and pull it out and take look...
