View Poll Results: A poll
Permatex High Temp Ultra Copper
6.67%
Permatex High temp Red RTV
26.67%
Permatex Ultra Black RTV
53.33%
Other (explain)
13.33%
Voters: 15. You may not vote on this poll
Which differential gasket maker to use.
Old Oct 16, 2006 | 04:05 PM
Silver_Dodge's Avatar
Silver_Dodge
Default Which differential gasket maker to use.
Which is the best silicone gasket maker to use on differentials:
-Permatex High Temp Ultra Copper
-Permatex High Temp Red
-Permatex Ultra Black
-Other
Old Oct 16, 2006 | 04:17 PM
Maintain's Avatar
Maintain
Default RE: Which differential gasket maker to use.
I used the Black RTV, however my stepdad's F250 had the Red RTV on it when he bought it.
Old Oct 16, 2006 | 05:02 PM
jakebrake's Avatar
jakebrake
Actually, all will work equally good. I've sealed dozens of diffs at work with all the above. All of them have over 100,000 miles and don't leak.
Old Oct 16, 2006 | 06:58 PM
steve05ram360's Avatar
steve05ram360
I used the red of my last 4 diff servicing, never had a problem
Old Oct 16, 2006 | 11:07 PM
Socha_62's Avatar
Socha_62
I've used the blue stuff, had it off at LEAST 6 times. Zero leaks.
Old Oct 17, 2006 | 03:50 AM
dxj_1's Avatar
dxj_1
2500 and I haven't had any problems with the red so I'm sticking with it.
Old Oct 17, 2006 | 12:15 PM
GOD RAM IT's Avatar
GOD RAM IT
ORIGINAL: Socha_62
I use the blue stuff as well
I have also used red and that works the same
Old Oct 17, 2006 | 01:35 PM
Silver_Dodge
Well, I have always used the black, but I wanted to make sure that was a good choice. There is a really nice diff gear oil change write-up on another forum that recommneded using the copper. I also see a lot of differentials that have the red coming out around the bolts. I've never had any problem using black, but was just wondering what you all thought.
Old Oct 17, 2006 | 02:38 PM
dillonjm's Avatar
dillonjm
You don't need the red on the diffs. It's for high temp applications. The blue will work just fine.
Old Oct 17, 2006 | 02:44 PM
Tani1500's Avatar
Tani1500
i use blue or black, normally what ever i have lieing around. never had a problem.
