TPS
Old Oct 18, 2006 | 02:05 AM
buckindawoodz's Avatar
buckindawoodz
Default TPS
Are there any aftermarket TPS out there?
Old Oct 18, 2006 | 02:10 AM
steve05ram360's Avatar
steve05ram360
Default RE: TPS
not to my knowledge, it's a pretty basic part. there is a tps mod out there for you to do... drill out the mounting holes and slot them enough so that you can get .75Volts out of the sensor at idle. it is supposed to be good for better throttle response.
Old Oct 18, 2006 | 02:12 AM
buckindawoodz
Default RE: TPS
Really, never would've thought of that thanks for the tip though.......
Old Oct 18, 2006 | 02:28 AM
steve05ram360
Default RE: TPS
your welcome, if yo search the web for tps mod & dodge ram you should be able to find it. what i mentioned is about all it'll say though.
Old Oct 18, 2006 | 07:23 AM
Ramdamit98's Avatar
Ramdamit98
Default RE: TPS
You'll find more on the TPS mod here amonst tips
http://www.v8performance.com/tipsandtricks.htm
Old Oct 18, 2006 | 12:40 PM
timwag2001's Avatar
timwag2001
Default RE: TPS
i found this mod to kinda be a pain in the ***. its easy to get the volts to .75 but once you try bolting it on it changes.
Old Oct 18, 2006 | 03:30 PM
BeachCrawler's Avatar
BeachCrawler
Default RE: TPS
Thet are available at Autozone and Advance Auto, Pepboys, etc. for around $50.00.
