transmission noise or power steering noise help
Old Oct 25, 2006 | 11:28 PM
ajwines's Avatar
ajwines
Default transmission noise or power steering noise help
I have a 97 ram 1500 V8 2WD. When first starting truck in the morning cold putting it in reverse it makes a noise like power steering is dry but its not. The noise sounds like its coming from transmission. Does not make the noise in forward position and when the truck is warm the noise does not happen when putting in reverse. Any ideas on what this could be? Thanks
Old Oct 26, 2006 | 04:40 AM
silverram99's Avatar
silverram99
Default RE: transmission noise or power steering noise help
This is a common problem on our trucks. Here is a thread that addresses what you are talking about.
https://dodgeforum.com/m_281686/tm.htm
As stated in that thread there is a TSB for this, put most mechanics agree that it is normal. I'm pretty sure there is no real fix to this though.
Welcome to the forum.
