What next?
Old Oct 26, 2006 | 05:14 PM
MorganM's Avatar
MorganM
Default What next?
Well, I just got done putting a flowmaster 40 series on my 2000 3.9L ram 1500. It definately feels like it has more power and is being less restricted. For my next project I want to either put a high flow cat, a new TB, or a cold air intake on it. Right now I have the stock air box with a K&N filter in it. What would you guys reccomend?
Old Oct 26, 2006 | 05:22 PM
steve05ram360's Avatar
steve05ram360
Default RE: What next?
get a stock v8 TB for it, cheep and easy 10 hp. (or so i was told when I was looking). all yo have to do is swap the linkage.
Old Oct 26, 2006 | 07:19 PM
MorganM's Avatar
MorganM
Which part is the linkage? And it will fit on the same as the V6 TB?
Old Oct 26, 2006 | 07:21 PM
MorganM's Avatar
MorganM
Also does it matter if it is from a 5.2L or a 5.9L?
Old Oct 26, 2006 | 07:58 PM
JD770's Avatar
JD770
if you already have the K&N the cold air INDUCTION will not make a difference.
Dont replace the cat unless its faulty. Most shops won't do it anyway. Try the TB, open your intake up to match it if possible otherwise 10hp would be a stretch.
Old Oct 26, 2006 | 08:39 PM
dirty dog's Avatar
dirty dog
get a v8
Old Oct 26, 2006 | 09:33 PM
steve05ram360
he's got the v6 which is better for some anyway, cant get them into too much trouble. the linkage I THINK is different, if it is, you should be able to take it to a carb shop and they may be able to swap it over for you. I dont recall what the mounting looked like on mine since its been a while.
