Edelbrock Heads
Old Nov 3, 2006 | 01:11 AM
kikidbird's Avatar
kikidbird
Default Edelbrock Heads
Hello everone, Im still working on my 99 318 block. I just slapped on some Edelbrock 61779 heads, but I encountered a snag. I bought some Harland Sharp 1.7 roller rocker # S70037, but they dont fit. I want to install a 1.7 ratio rockers and Iwas looking for some sugestion. Thanx
Old Nov 3, 2006 | 11:50 AM
JD770's Avatar
JD770
Default RE: Edelbrock Heads
you are better off changing the valve train specs with a cam, if the block is already out its cake to change and less $ than the rockers for more HP.
Old Nov 7, 2006 | 12:38 AM
kikidbird's Avatar
kikidbird
Hello, I have installed a Comp Cam Xtreme pn# 20-745-9. I really want to install 1.7 roller rockers, but I dont know who makes them.
Old Nov 7, 2006 | 12:49 PM
JD770's Avatar
JD770
harland sharp makes the best set Ive seen, but check your lift specs to make sure you won't float a valve or cause contact.
my bet is though that you wont realize anymore gains than the Cam.
Old Nov 7, 2006 | 02:01 PM
Socha_62's Avatar
Socha_62
Have aftermarket valve covers? You might start hitting the covers if not. Mopar Performance covers are nice.
Old Nov 7, 2006 | 11:58 PM
kikidbird's Avatar
kikidbird
I cant use the Harland Sharp becase the studs are for 5/16, and the Edelbrock Heads studs are 3/8. I am using the aluminum Mopar Magnum valve covers.
Old Nov 8, 2006 | 12:51 AM
shortram's Avatar
shortram
did you call comp cam and/or edelbrocks tech lines? one of them should have a solution for you. i do know you are going to have to check valve to piston clearences very carefully if you are going to run a higher lift/duration cam with 1.7 rockers with a stock style piston.
