O2 problem/question
Old Nov 3, 2006 | 11:15 PM
trippinout's Avatar
trippinout
Default O2 problem/question
Don't have problem right now, but my CEL comes on if I use anything less than premium. Code is always P0132 O2 sensor high voltage bank 1, sensor 1. Replaced the o2 sensor, but it keeps popping the CEL (Yes, I unplugged the battery to clear the codes from the computer) if I run regular or mid-grade fuel. Can run those fuels, but have to put some Lucas oil in the gas to keep that code fm popping. Gotten the code 5 or 6 times now. Replaced IAC and speed sensor as well. Has been a few months now because we just keep running the expensive fuel.
Old Nov 4, 2006 | 05:38 AM
steve05ram360's Avatar
steve05ram360
Default RE: O2 problem/question
you dont mention which year your truck is... does it ping on the lower grades? if so check the plenum gasket for leakage.
Old Nov 4, 2006 | 11:02 PM
trippinout's Avatar
trippinout
Sorry, it's a 1998 5.2L and yes it pings on the lower octanes. I'll check those tomorrow. Thanks!
Old Nov 4, 2006 | 11:28 PM
ryans590's Avatar
ryans590
has your pcm been flashed?
