4wd is loud and vibrates
Old Nov 3, 2006 | 11:17 PM
htamotorsports's Avatar
htamotorsports
New Member
Default 4wd is loud and vibrates
i have a 96 1500 5.9 when its in rwd the truck runs mint, but when i engage it into 4hi its kind of loud and i feel vibration, the 4hi works fine, it just doesnt feel and sound smooth. also when i engage it into 4hi it takes liek 10sec for the light to come on or when i put it back in 2hi it also takes 10sec for the light to coem off.
Old Nov 4, 2006 | 01:14 AM
Tani1500's Avatar
Tani1500
Default RE: 4wd is loud and vibrates
getting a vibration at what speed and on what surface? rams have a part time transfercase and are not ment to be driven on dry roads or at speeds above 50 MPH
Old Nov 4, 2006 | 05:23 PM
htamotorsports
New Member
on wet surface, like when its raining,its loud from 1-50mph
Old Nov 4, 2006 | 05:43 PM
silverram99's Avatar
silverram99
Have you looked at the front drive shaft u-joints?
Old Nov 4, 2006 | 07:02 PM
DieselDemon's Avatar
DieselDemon
That double cardan assembly has a center ball bearing in it. If it goes bad, it makes a loud, dull, rubbing sound.
Good luck.
Old Nov 4, 2006 | 10:02 PM
ryans590's Avatar
ryans590
also check your front axle u-joints they go on mine quite frequentley and cause vibration in the front end
