motor dies
Old Nov 5, 2006 | 06:08 PM
RJlovesbeer's Avatar
RJlovesbeer
Default motor dies
i have a 96 ram 4x4. when im driving i lose power stering and the brakes get real hard to push. about a second later the motor dies. i just changes the oil presure sensor thinking that might be the problem. has anyone even enconutered this, if you have can you help me out. anything would be great.
Old Nov 5, 2006 | 06:30 PM
steve05ram360's Avatar
steve05ram360
Default RE: motor dies
sounds like a fuel pump dying... does it start right back up?
Old Nov 8, 2006 | 03:14 AM
tkid98's Avatar
tkid98
My 98 would cut out on me as I was driving. It did it only when the engine was warm. Turned out to be the Crankshaft Position sensor.
Can't say that was typical tho, because my mechanic couldn't believe it started at all!
Ran like a bear first thing in the morning! Stalled every time I let off the gas in the afternoon.
Old Nov 9, 2006 | 02:51 PM
clutchn's Avatar
clutchn
ORIGINAL: tkid98
but wouldnt that set off a check engine light?
my 99 is doing the same thing, and im thinking its the fuel pump. im gonna mount a fuel pressure gauge on the hood, and drive it around till it dies again. if i see the pressure dropping, ill know if its the fuel pump assembly or not. it also idles slightly higher than normal, and i did the plenum fix about 8 months ago.
