Changed my oil
Old Nov 6, 2006 | 05:51 AM
habeba86's Avatar
habeba86
Default Changed my oil
and the oil cap[:@] Nothing got inside so thats good...The inside of the cap jst busted up into a bunch of peice and I couldnt unscrew the cap. So I had to pop off the cover that twist and then get the peice that screws into the valve cover off. I got some vice grips and got it out. Now I get to drive an hour to buy a new one[:@]
Old Nov 6, 2006 | 12:14 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Changed my oil
Hope you closed with hole with duct tape or something to prevent contaminants from getting into the crankcase.
Old Nov 6, 2006 | 04:43 PM
habeba86's Avatar
habeba86
I did....I got a new cap already, she ready to go again
Old May 12, 2007 | 01:25 PM
CopperDesigno's Avatar
CopperDesigno
Was the symptom of this just the yellow oil cap top clicking and spinning without coming of the valve cover?
I am in the middle of an oil change on my 96 1500 and I can't get the cap off. It just clicks and spins like its trying to grab something.
How do I get it off cleanly without putting a bunch of plastic bits into the engine?
Thanks
Old May 12, 2007 | 01:32 PM
CopperDesigno
Never mind, I decided to do what habeba86did and pop off the outer cap and use vise grips to loosen and remove the inner cap from the valve cover. I should have figure something wasup during the last oil change when the cap started to click. So for those of you with a clicking oil fill cap, replace it, it's less ten bucks at the parts store.
