Try thr new Accel coil on dodge
Old Nov 8, 2006 | 11:00 PM
mopar98's Avatar
mopar98
Default Try thr new Accel coil on dodge
I have recently put a Accel coil on my 98 2500 Dodge and there is deffinetly a difference .
It feels like the power band is better and the throttle response is better.
I recommend them to any 2nd gen owner. The only problem is after 97 you have to buy a wire adapter.
Cost a little but Ithink it was worth .
Old Nov 8, 2006 | 11:45 PM
dirty dog's Avatar
dirty dog
Default RE: Try thr new Accel coil on dodge
i think im going to get the msd kit with coil,wires,rotor, and cap
its like $322 but from what i hear is worth it
Old Nov 9, 2006 | 04:42 PM
turkeyhunter1962's Avatar
turkeyhunter1962
I have the Accel coil and wiring adapter and yes it is worth it for the price as it is a reasonably proced upgrade over stock. However, when I have the $300 + bucks just laying around I will be upgrading to the MSD system.
Old Nov 9, 2006 | 04:46 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
What are the benefits of the MSD system?
Old Nov 9, 2006 | 05:54 PM
silverram99's Avatar
silverram99
ORIGINAL: VWandDodge
I'm not sure which system they are refering to. The one dirty dog talked about is just a kit with an MSD branded cap, rotor and wires. The coil it comes with is probably a blaster2 or 3. I'm pretty sure that you know the benefits of getting larger than stock plug wires with less resistance. The coil simply produces a higher voltage for the spark plugs, this will burn the air/fuel mixture more effeciently.
To take it one step further, I would reccomend getting the blaster 3 coil with an MSD 6A box. The MSD (multiple spark discharge) box will make the spark plug fire 3 times for each powerstroke of the motor when it is under 3000 rpm, this coupled with the high-output coil will produce a more complete burn of the air/fuel.
Heres the way I look at it, I got my MSD box brand new for 100 bucks. I think they usually cost around 300, I have an internally stock engine with a few bolt on's so for my setup the coil/box upgrade wasn't really neccesary. So if your coil goes out on you or you have the extra $500 laying around go for it and be sure to use a cap/rotor set with brass terminals and upgraded plug wires that will handle the increased spark better. You will have to replace your cap, rotor and plugs about 3 times as often though.
Old Nov 9, 2006 | 06:03 PM
nihlcat's Avatar
nihlcat
I only have about 1K on my Accel coil. I have upgraded wires as well. The combination has given a mild increase in throttle response.
Old Nov 11, 2006 | 08:17 AM
HankL's Avatar
HankL
When the Accel coil came out several years ago
a lot of owners tried them
and 6-12 months later a lot of them had died in service.
(its a good idea to carry your original stock coil in the truck)
Accel has had several years to improve the durability
and I hope they have.
The Dodge MSD replacement coil is very similar to the Accel
and I can't remember reading of a failure.
various technical specs of 5.2/5.9 ignition coils:
Here's what the Accel catalog says about their Magnum Truck coil:
begin quote:
"DODGE "MAGNUM"
TRUCK / JEEP 1997-90 SUPER COIL
Engineered with optimized low resistance, high turns ratio windings around an
M36 high silicone magnetic steel C-core for higher energy and voltage outputs.
Results in quicker starts, improved idle quality, crisper throttle response
and more high RPM power. Compatible with late model MOPAR J-TEC computer
controlled ignition system and MOPAR high performance ignition computers.
Direct bolt-in, plug-in replacement. Can also work with an ACCEL, Mallory,
Crane, Holley or MSD capacitive discharge ignition systems. Special high
temperature epoxy resists shock and vibration, while increasing thermal
conductivity. Brass coil wire contact increases energy transfer efficiency and
resists corrosion better than aluminum. High dielectric strength "ACCEL
Yellow" over molded housing.
SPECIFICATIONS
Primary Resistance 1.0 Ohms
Secondary Resistance 12.7 k Ohms
Turns Ratio 76 : 1
Maximum Voltage 42,000 volts
Peak Increase in Energy vs. OE 34%
Peak Increase in Current vs. OE 17%
Peak Increase in Arc Duration vs. OE 23%
Peak Increase in Dwell vs. OE 36%
Dodge "Magnum" Truck / Jeep 1997-90 Super Coil . .140021"
end quote
MSD Magnum Engine replacement coil
primary 1.2 ohms
secondary 13,700 ohms
For Info,
Here is what I measured on my 1995 model year stock Ram ignition coil this
afternoon:
Number on side of coil: 56027966
Primary Resistance 0.99 ohms
Primary Inductance 6.25 milliHenrys
Secondary Resistance 12,250 ohms
Secondary Inductance 41.9 Henrys
I put 6.3 volts of 60 cycle AC on the primary of the stock coil and got 453
volts AC on the secondary. The turns ratio of the stock coil might be about
453/6.3 = 72
A lower turns ratio can be good in that it prolongs the 'burn time' of the spark
especially at high rpms.
A higher turns ratio can provide a higher voltage to get the spark to jump
but most of the time a higher voltage is not needed. Exceptions are
when the plug is fouled with oil or gasoline, the tip edges have become dull,
or when the tips are cold when the engine is first started.
Above measured with a seventeen year old BK Precision LCR Meter model number
875A and a Fluke 87.
The 1995 FSManual says the coils are made either by Diamond or ToyoDenso.
For the Diamond the primary resistance is supposed to be between .97 and 1.18
ohms and the secondary 11,300 to 15,300 ohms.
For the Toyodenso the pri resis is supposed to be between 0.95 and 1.20 ohms
and the sec 11,300 to 13,300 ohms.
Here's what MSD says about the Blaster SS:
begin quote
Blaster SS Coil, PN 8207
The MSD line of Blaster Coils is known for great performance from the street
to the circle tracks. Following in that performance line, the new Blaster SS
Coil is ready to leave its mark.
The Blaster SS is an E-core style coil, which is a very efficient design when
it comes to producing high voltage and spark energy. The windings produce
300mA and can handle up to 48,000 volts when used with an MSD 6 Series
Ignition Control. The windings are held secure in a Dupont® RyniteT injection
molded shell and are then encased in an epoxy compound for protection against
vibration and water. The primary terminals are located at opposite ends of the
tall spark tower so there is no chance of arcing especially with the high
dielectric characteristics of the Rynite housing.
The Coil is compact enough to fit in tight areas and is supplied with
vibrations mounts.
Blaster SS Coil - PN 8207 CARB Approval Pending
BLASTER SS COIL SPECIFICATIONS
Primary Resistance: .355 ohms
Peak Current: 300mA
Secondary Resistance: 6,200 ohms
Spark Duration: 180uS
Maximum Voltage: 48,000 volts
Primary Inductance: 6milliHenrys
Turns Ratio: 70:1 Tested with an MSD 6AL
measured at plug gap.
Bowling Ignition Circuit Simulator
Stock Ram Ign Coil part number 56027966
Input Parameters Are the Following:
Starting RPM = 500
Ending RPM = 5000
RPM Step = 250
Ignition Coil Primary Resistance (Ohms)= 1.0
Ignition Coil Primary Inductance (Millihenries) = 6.2
Dwell Angle (Crankshaft Degrees)= 30.0
Battery Voltage = 12.0
Ignition Coil Secondary Capacitance (Picofarads) = 100.0
Computation Results:
Engine Charge Time Primary Current Secondary Voltage Energy
RPM (millisec) (Amps) (Volts) (Joules)
500 10.0000 9.58 75714.7 0.287
750 6.6667 7.87 62219.0 0.194
1000 5.0000 6.61 52241.2 0.136
1250 4.0000 5.67 44845.0 0.101
1500 3.3333 4.96 39214.2 0.077
1750 2.8571 4.40 34808.1 0.061
2000 2.5000 3.96 31276.2 0.049
2250 2.2222 3.59 28386.1 0.040
2500 2.0000 3.29 25979.8 0.034
2750 1.8182 3.03 23946.3 0.029
3000 1.6667 2.81 22206.0 0.025
3250 1.5385 2.62 20700.1 0.021
3500 1.4286 2.45 19384.5 0.019
3750 1.3333 2.31 18225.5 0.017
4000 1.2500 2.18 17196.7 0.015
4250 1.1765 2.06 16277.5 0.013
4500 1.1111 1.95 15451.4 0.012
4750 1.0526 1.86 14704.8 0.011
5000 1.0000 1.77 14026.9 0.010
CraneCams LX91 Ign Coil
Stock Ram Coil Part number 56027966.................Crane LX91
Pri Resistance 0.99 ohms....................................0.41ohms
Pri Imped 6.25 mh...............................................5 .3mh
Sec Resis 12,010 ohms......................................3,170 ohms
Sec imp 41.9 Henrys...........................................1 7.1 Henrys
Simulation using Bowlings program:
Starting RPM = 500
Ending RPM = 5000
RPM Step = 250
Ignition Coil Primary Resistance (Ohms)= 0.4
Ignition Coil Primary Inductance (Millihenries) = 5.3
500 10.0000 15.64 113833.3 0.648
750 6.6667 11.73 85363.4 0.364
1000 5.0000 9.35 68047.3 0.232
1250 4.0000 7.76 56505.2 0.160
1500 3.3333 6.63 48286.3 0.117
1750 2.8571 5.79 42144.1 0.089
2000 2.5000 5.13 37383.0 0.070
2250 2.2222 4.61 33585.5 0.056
2500 2.0000 4.19 30486.8 0.046
2750 1.8182 3.83 27910.6 0.039
3000 1.6667 3.54 25735.2 0.033
3250 1.5385 3.28 23874.0 0.028
3500 1.4286 3.06 22263.6 0.025
3750 1.3333 2.86 20856.4 0.022
4000 1.2500 2.69 19616.5 0.019
4250 1.1765 2.54 18515.6 0.017
4500 1.1111 2.41 17531.6 0.015
4750 1.0526 2.29 16646.8 0.014
5000 1.0000 2.18 15847.1 0.013
Bowling and Grippo's ignition simulator is at
http://www.bgsoflex.com/igncoil.html
This is the team that started the MegaSquirt "open source" electronic fuel injection project.
Old Nov 11, 2006 | 12:57 PM
nihlcat's Avatar
nihlcat
HankL, I have read of their unreliability elsewhere on this board, so yeah, I keep my old coil in the cab just in case. My impovements are a smoother cold start, and about 100 less RPMs at 65 MPH. I had looked at the MSD bolt on (8228), but the voltage was less. I'll admit, I chose a bolt on replacement because I didn't feel confident changing up the wiring.
Old Nov 11, 2006 | 05:42 PM
mopar98's Avatar
mopar98
I have been using Accel coils for awhile now on my other trucks and cars and never had a prob. But I have heard of guys having probs so maybe I might put my stock one in my tool box for just in case Thanks for the feed back [sm=smiley20.gif]
Old Nov 12, 2006 | 06:17 AM
IndyRamMan's Avatar
IndyRamMan
http://store.summitracing.com/partde...5&autoview=sku
Good price for one?
Im thinking of getting one, just because the previous owner did the rest of the ignition up with accell parts, except the coil.
