plenum
Old Nov 10, 2006 | 01:12 AM
lb1995ram's Avatar
lb1995ram
Default plenum
I have been reading alot of posts adn there are quite a few that are talking about a plenum! what is it? were is it? cuz i have a leak of some sort and i was just wondering if this may be it!
Old Nov 10, 2006 | 02:43 AM
silverram99's Avatar
silverram99
Default RE: plenum
Here is the TSB dealing with a leaking plenum:
http://dodgeram.info/tsb/2000/09-05-00.htm
Also try searching for plenum, you should find enough threads to keep you busy for days.
Old Nov 10, 2006 | 03:21 AM
steve05ram360's Avatar
steve05ram360
Default RE: plenum
it's on the bottom of the intake manifold... it bolts up to it and there is a gasket that will leak because the manifold is aluminum and the cover is steel... they heat and expand at different rates causing the gasket to tear and leak.
