K&N FIPK No More
Old Apr 3, 2007 | 09:46 PM
  #281
mcss8541's Avatar
mcss8541
Default RE: K&N FIPK No More
Naw I got it thanks I appreciate it.
Old Apr 11, 2007 | 07:38 PM
  #282
LomcevakDuck's Avatar
LomcevakDuck
Hey guys I got the Mopar air cleaner from Summit (first order from them and I'll be a customer for life.) Ordered yesterday and got it this afternoon without paying for overnight shipping. I'll be installing it with a Fastman 50mm TB and a K&N filter. I'll let you guys know how it works out here in the south where the weather is ungodly HOT in the upcoming months.
Old Apr 11, 2007 | 09:38 PM
  #283
Silver_Dodge's Avatar
Silver_Dodge
Ya, that's my only concern, how it will do in the heat. July and August here in Colorado can be in the 90's and higher depending on where you go. That's why I kept my FIPK just in case this setup doesn't do as good for those few months. It kicks *** in the winter time though.
Old Apr 11, 2007 | 11:14 PM
  #284
mcss8541's Avatar
mcss8541
What part of South Texas do you live? I'm down here in El Campo, TX and let me tell you it gets hot as hell. Colorado 90 dgrs is respectable I'll give you that but OUR 90 dgrs packs a 100% humidity with it so it feels more like 115 - 120 and I am anxious to see how that air cleaner setup works. I'm in line to get that exact package so keep me informed. Also what was the total out-of-pocket expense for everything including shipping so I'll know how much to put in my piggy bank.
[IMG]local://upfiles/56056/459DEFDB716C46FB9C3EAFC67071E63A.jpg[/IMG]
Old Apr 11, 2007 | 11:27 PM
  #285
mcss8541's Avatar
mcss8541
Silver_Dodge I viewed your cardomain page and man you've done alot to your ride and it looks great. Question what is a "flashed" pcm and what are the benefits? Where did you get that trans pan? Man I would like one like that. Is your exhaust 1 in then dualed from the muffler or cat? And lastly where did you get the trans cooler/fan setup and where did you install it? I have a 98 with a 5.9L and the tranny has already been rebuilt a couple of times by the previous owner and man during the Texas summers the heat can be brutal. Thanks again.
Old Apr 11, 2007 | 11:38 PM
  #286
LomcevakDuck
mcss8541- I don't live in TX at all. I live in Alabama.
Old Apr 11, 2007 | 11:58 PM
  #287
mcss8541's Avatar
mcss8541
My bad :-) I thought you said you live in south Texas......well if you are ever this way stop by and sit awhile. But let me know how your setup works. Thanks!
Old Apr 12, 2007 | 01:40 AM
  #288
Silver_Dodge
ORIGINAL: mcss8541
My Mopar setup came up to about $110 total. Others on here have done similar for less then $50 though, using the 14x3 filters you can buy at most parts stores.
Old Apr 12, 2007 | 01:46 AM
  #289
Silver_Dodge
ORIGINAL: mcss8541
Thanks. To answer your questions:
A flashed PCM is where a company (in this case B&G) take your stock PCM and reprogram it to work specifically with the mods you have. They also do some other stuff like remove torque management, adjust shift points, raise your idle, etc.... It is like a Hypertech or Superchips programmer on steroids. One of the best mods I have done from a performance standpoint.
The trans pan came from PML It adds an extra 2 qts capacity. http://www.yourcovers.com/tp_9393.shtml
No, my exhaust is single in, single out. It is 3" from the cat out.
My trans cooler came from flexalite, and it is that huge thing installed in the front of my radiator. It is rated at 32,000gvw, so it gets the job done.
Old Apr 12, 2007 | 10:40 AM
  #290
mcss8541's Avatar
mcss8541
Do I have to send my PCM to them or do they ship a programmer type apparatus to you?
