Bolt on power info?
Old Nov 14, 2006 | 11:01 PM
mopar98's Avatar
mopar98
Default Bolt on power info?
Need a bolt on for power . My buddy will be having a truck pull on his farm in 2 weeks and I don't want anyone showing me up.
I will be the only gas powered dodge there any ideas guy . I've looked into fastman TB and hace been wondering about programmers and under drive pulleys.
Old Nov 14, 2006 | 11:24 PM
TMS Bill's Avatar
TMS Bill
Default RE: Bolt on power info?
Programmer (hi octane setting with a tankful of 93)
Fastman - (50mm for 5.2L ... 52mm for 5.9L)
180* thermostat
Crank Sensor mod
Use 4-Lo ...
Old Nov 14, 2006 | 11:27 PM
mopar98's Avatar
mopar98
I always use 4 low and what is the crank sensor mod?
Old Nov 14, 2006 | 11:35 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: mopar98
From KRC Performance:
Your timing is set initially by the crankshaft sensor and the distributor has the camshaft sensor in it to determine when the injectors fire relative to the amount of valve opening. So moving the distributor does not affect base timing. But moving the crankshaft sensor relative to it's current position does. The trick is this, and takes about one hour. This will work on any Dodge truck 92- to present except for the 4.7L or the V-10.
Remove the crankshaft sensor on the aft/passenger side of the block. It is held down by (2) 1/2" bolts and pulls out of the tranny bell housing when loose. There is a rubber grommet in the bell housing also, remove it. Now look at the sensor's bracket, notice the 2 bolt holes. Slot each hole 3/8" both ways, still giving the bolts something to hold onto. Then insert the sensor back into the bell housing, making sure you pulled out the rubber grommet. Thread the 2 bolts back in loose, then slide the sensor as far as it can, towards the oil filter, away from the intake. This will advance, moving it towards the intake in the same direction of crank rotation and will retard the base timing; do not do this unless your teenager is driving the truck. It will usually be limited by the bell housing how far you can move it. If you are really brave, grind the bell housing and fab a new adjustable bracket. This will add 3-4 degrees of timing across the whole board of advance tables.
Old Nov 14, 2006 | 11:38 PM
ripto's Avatar
ripto
ORIGINAL: TMS Bill
180* thermostat
Crank Sensor mod
Use 4-Lo ...
Or 50mm for the 5.9 if you want more low end
Old Nov 14, 2006 | 11:40 PM
mopar98's Avatar
mopar98
THANK U I will try it . and I believe I will order the porgrammer and the fastman 52 TB. I'LL JUST KEEP IT A SECRET UNTIL AFTER THE PULL.
Those other guys won't know what to think about my Billy goat walk away with them.[sm=gears.gif]
Old Nov 14, 2006 | 11:42 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: ripto
ORIGINAL: TMS Bill
180* thermostat
Crank Sensor mod
Use 4-Lo ...
If he's pulling in 4-Lo ... he's gonna want high end. 52mm is called for.
Old Nov 14, 2006 | 11:43 PM
ripto's Avatar
ripto
Oh i see.
What is the cut off between "low end" and "high end" - ~3000 RPM?
Old Nov 14, 2006 | 11:51 PM
mopar98's Avatar
mopar98
Got to go to work thanks again for the info guys . When I get home in the morning I'm gonna call summit or jegs ,and order the programmer and under drive pulley . Then I'll start networking for the fastman. I have plenty of time this weekend for the work and if I hit a snag I'll ask yall for help. Bye[sm=hiya.gif][sm=hiya.gif]
Old Nov 14, 2006 | 11:57 PM
ripto's Avatar
ripto
take videos :P
