52 mm to much
Old Nov 18, 2006 | 03:18 AM
Scottr1110's Avatar
Scottr1110
Default 52 mm to much
on ebay there is a hughes billet 52 mm thottlebody for 299 do u think this would be over kill for a preatty much stock 318 is it going to hurt my power by letting to much air in or what
Old Nov 18, 2006 | 03:34 AM
helmsa's Avatar
helmsa
Default RE: 52 mm to much
fastman is only $225 if you mention the forum.
Old Nov 18, 2006 | 04:11 AM
Scottr1110's Avatar
Scottr1110
well if i go with the billet one what should i go with with a 318 with just bolt ons
Old Nov 18, 2006 | 05:00 AM
helmsa's Avatar
helmsa
Fastman sells the 50mm for the 318...and for the 360 towing application...52mm would kill your lowend on a 318 as it is designed for the 360 performance...
Old Nov 18, 2006 | 06:25 AM
Zeppelinrocks's Avatar
Zeppelinrocks
from what i heard get the fastman everybody here swears by it
Old Nov 18, 2006 | 04:29 PM
RM_Indy's Avatar
RM_Indy
ORIGINAL: helmsa
Good advice
Old Nov 18, 2006 | 06:29 PM
kevo2k6's Avatar
kevo2k6
ORIGINAL: helmsa
i'm not sure the 52 would "kill" your low end. i think you are just going to see gains higher in the rpm range with the 52mm and lower in the rpm range with the 50mm.
