flasher relay
Old Nov 19, 2006 | 12:30 AM
IndyRamMan's Avatar
IndyRamMan
Default flasher relay
im assuming the relay is on the bottom side of the stearing column? anything i should know before doing it? any tabs or something i may break that i should take note of?
Old Nov 20, 2006 | 02:13 AM
DieselDemon's Avatar
DieselDemon
Default RE: flasher relay
Isin't your flasher relay in the fuse block that is located inside the cab? Look for a round plastic, or metal shaped object adjacent to the fuses. About the diameter of a $.50 cent piece.
Good luck.
