misfire
Old Nov 21, 2006 | 01:19 AM
timwag2001's Avatar
timwag2001
Default RE: misfire
yup
Old Nov 21, 2006 | 01:39 AM
Glideman88's Avatar
Glideman88
Default RE: misfire
I had a #5 misfire code just last week when I started up my truck after work.
I decided the first thing I would check when I got home would be to "read" the spark plug and troubleshoot from there. I had just replaced the plugs and wires a couple months ago, but I was in still in town, so I stopped at the parts store and picked up 1 spark plug just in case.
I'm really glad I picked up a spare plug!!! When I pulled the wire off the plug almost half of the insulator came off with the wire! The spark plug had literally broken in two and only the rubber boot on the plug wire was holding it in place. So, I simply replaced the spark plug, disconnected the battery for 15 minutes to reset the computer, drank a couple of ice cold Buds, hooked the battery back up and life is good!
Old Nov 21, 2006 | 09:04 PM
quadro's Avatar
quadro
Default RE: misfire
well that mkes me feel better, maybe something that simple. still havent had time to check it though . hopefully tomorrow if I get out of work early enough. thanks for all the ideas guys. I'll let you know what happens
Old Nov 22, 2006 | 11:34 PM
quadro's Avatar
quadro
Default RE: misfire
weel I finally got to take a look at my truck. checked the wires make sure they werent cracked, started it up, and no CEL. well some much for figuaring out what it was. I'll just have to drive around and see if it comes back on. thanks for the suggestions guys
