bring the front up a couple inches
Old Nov 20, 2006 | 12:24 AM
kevo2k6's Avatar
kevo2k6
Default bring the front up a couple inches
i want to bring my front up about and inch and a half or 2 inches. i already have coil spacers in the front. if i swap out the stock 1500 springs with diesel or v10 springs will i get about 2 inches? will this be ok to do with already having coil spacers?
Old Nov 20, 2006 | 01:17 AM
helmsa's Avatar
helmsa
Default RE: bring the front up a couple inches
The 2500/3500 HD springs would give you way more than 2" (don't remember the total amount). You could look for some springs off an OFF ROAD.
Old Nov 20, 2006 | 01:51 AM
20dodgeram01's Avatar
20dodgeram01
v10 and diesel coils is about 1.5 - 2 inches.. same as an offroad.. but the springs are much stiffer because they need to handle the weight of a diesel engine.. stiffer springs.. stiffer ride.. go for a offroad ram coils.. also if you already has 2 inch spacers.. and you still need 2 more inches.. your front end is really sagging.. if you just get regular coils off a 4x4 ram then it should even it out since a 2 inch spacer is suppose to level it out in the 1st place..
Old Nov 20, 2006 | 02:05 AM
kevo2k6's Avatar
kevo2k6
its not sagging in the front. i just have smalls blocks and air bags in the back. if anything i want the front to be a tiny bit higher. but am i gunna run into any problems with using v10 springs along with the spacers i have? ill probly need longer shocks right?
Old Nov 20, 2006 | 02:09 AM
20dodgeram01
3+ inches in the front need new shocks.. so yeah most likely you will.. and you wont have a problem with 2500 springs in the front.. they are the same width just longer.. i got a set of rancho 5000 shocks at autozone for 90 bucks for a 2-4 inch lift
Old Nov 20, 2006 | 11:22 AM
don_ripley's Avatar
don_ripley
How much taller are Sport springs compared to a regular 4x4 springs?
Old Nov 20, 2006 | 11:42 AM
pollocksn's Avatar
pollocksn
the sport springs are not any taller than a regular 4x4. If you want you can get some skyjacker lift springs you can get a 2 or 3 in lift coil and still use the lift spacers. You can get them from summit I believe for around $120 or so.
