Odd offroad mishap
Old Nov 20, 2006 | 02:50 PM
MAGICDSSMAN's Avatar
MAGICDSSMAN
Default Odd offroad mishap
Well sunday night I decided to going to a very remote area and test fire my new pistols (bought a 22 and a 9mm). This morning I went out to check my undercarriage and everything to make sure I didn't do any damage this weekend. Well to my surprise I found a plastic bag sucked into the yoke of the rear differential and is causing gear lube to leak everywhere.
Now to my question When I remove the bolt for the yoke on the rearend is anything going to fall apart inside the pumpkin? I have never had to remove the yoke only the driveshaft. Any help or advice would be greatly appreciated.
Old Nov 20, 2006 | 03:01 PM
Tani1500's Avatar
Tani1500
Default RE: Odd offroad mishap
i have no clue how you managed that but taking off the yoke might throw your pinion shaft out of position. i would try to get it out some other way
Old Nov 20, 2006 | 03:04 PM
jakebrake's Avatar
jakebrake
Nothing will come loose. You should be fine. You'll probably need a good impact toget the yoke off. You'll also need a new seal.
Old Nov 20, 2006 | 03:19 PM
MAGICDSSMAN
Hopefully this works here is a pic
[IMG]local://upfiles/15396/6123E109BB184DFB95CD57B2F5C11989.jpg[/IMG]
Old Nov 20, 2006 | 07:11 PM
MAGICDSSMAN
Alright guys I got the yoke off and replaced the seal and diff fluid took about 2 hours total. The the pinion didn't move at all and all I needed to remove the nut was my 15" ratchet, a 33mm socket, and my hub puller. The yoke is a very tight fit on the splines so I had to very very carefully tap it back on. I kindof cheeted though to line the yoke back up with the drive shaft I put the Tcase in nuetral to turn the driveshaft.
