odd noise
Old Nov 23, 2006 | 01:01 AM
charger324's Avatar
charger324
Default RE: odd noise
Hey guys i have the almost the same proplem but the noise i here it like a chearping nosie is the anybody know what this can be [IMG][/IMG]
Old Nov 23, 2006 | 01:08 AM
charger324's Avatar
charger324
Hey guys i have the almost the same proplem but the noise i here it like a chearping nosie is the anybody know what this can be thank you.the dealer said that it sounds like the sway bars and to put water on it and it will stop the noise but it does not work it does it when i let it run or idle
Old Nov 23, 2006 | 01:40 AM
DieselDemon's Avatar
DieselDemon
I have seen trucks where the pinion shaft nut was not properly torqued form the factory. They can loosen up. It happens.
Grab the drive shaft and see if there is any shuck where the pinion shaft enters the diff case. If there is, remove the drive shaft from the rear diff, and crank down that nut that holds the yoke onto the pinion shaft. Use an air gun if you have access to it. You'll have to look up your specific years torque specs.....
It's a long shot but.............lol.
Good luck.
Old Nov 23, 2006 | 02:38 PM
witchy woman's Avatar
witchy woman
In my experience, noises can be catagorized: U-joints make a ticking or clunking or thumping sound when they go bad. They also can cause vibrations. A whine generally indicates a bad bearing, though wheel bearings can click when rotated if some of the rollers are shot. Grinding or clunking or "chuffing" usually means a bad gear or one with damaged teeth.
I've also had fuel pumps go bad and they can whine too. But they whine or hum at idle too.
I hate it when my vehicles make a new noise, especially one that comes and goes. Though rabbit to chase sometimes.
Old Dec 24, 2006 | 12:51 AM
roadrunner7373's Avatar
roadrunner7373
If its a faint noise it might just be the electric fuel pump. Or not.
