thermostat temp
Old Nov 25, 2006 | 06:03 PM
ciera56's Avatar
ciera56
Default thermostat temp
I was hoping someone could help me, I have a 1 ton diesel dodge the thermostat needle started going back and forth rel slow, it goes up to 210 then stays a minute or so and then goes back to 165 or so back and forth very slow though. put in a new therm and new radiator, nothing new, it doesn't leak any anti freeze either. had the radiater pressure tested, nothing. It has never over heated either.
Any suggestions? Thanks ciera56
Old Nov 26, 2006 | 03:34 PM
DeadLifter's Avatar
DeadLifter
Default RE: thermostat temp
I'm guessin that's where the fan kicks on and off.
Old Nov 26, 2006 | 04:14 PM
bamory's Avatar
bamory
Sounds like temp sensor/ 40* is alot to cool down to when fan kicks in.
Old Nov 26, 2006 | 07:13 PM
mopar98's Avatar
mopar98
I would assume the sending unit for the gauge is bad not sure of it's location ,but it's something to look at.[sm=confused06.gif]
Old Dec 1, 2006 | 10:13 PM
ciera56's Avatar
ciera56
I want to thank you for the responses. I'm a female so its hard to know what to do. I'll have all of the above checked.
