low beam flickers
Old Nov 28, 2006 | 11:40 PM
1980blackfiveoh's Avatar
1980blackfiveoh
Default low beam flickers
With the cold weather my drivers side low beam is flickering with bumps in the road. The high beam is fine so is the lowbeam burning out really slowly or the bulb is broken? It it too cold to pull the batery and really check it, I assume I need to pull the battery because there is no room otherwise. I tried wiggling the headlight wiring without success. I hate cold weather! It looks like I'm driving around and my truck is winking at other cars.
Old Nov 28, 2006 | 11:59 PM
mopar98's Avatar
mopar98
Default RE: low beam flickers
I've changed my light bulbs 2 times now and I've never needed to pull the battery u just need to wiggle your paw in there and turn the collar and unplug the bulb from the wire harness.
Old Nov 29, 2006 | 07:13 PM
1980blackfiveoh
Really, I'll give it another try when it warms up a bit. I'd rather not remove the batterey The light is dead now which is much beter than flickering on an off.
