Transmission Trouble?
Old Nov 29, 2006 | 10:36 PM
Bob5150's Avatar
Bob5150
Default Transmission Trouble?
My '99 Raam 1500 with the 5.2L and auto transmission is acting up. When I go from a dead stop, the truck will go, but it doesn't seem to have very mich power. The engine will get to about 2500 RPM's before it shifts out of first. Then, it hesitates, and then will shift back into first, the engine revs to almost 4000 RPM's, and the truck will gain speed, but it still lacks power. Does anyone know what the problem could be? Could a dirty air filter cause this? I know that the filter is dirty, and I have a new one waiting to be installed, but I don't know how to do it. I undo the 3 clips on the front of the box, but this doesn't seem to be the way to get it open. Does anyone know how to do this, and could you give me very specific instructions? I'm still new to the car maintenace thing. I just got into cars when I got my liscence 2 years ago, and I'm still learning. Any help would be greatly appreciated!
Old Nov 30, 2006 | 01:11 AM
scbcman's Avatar
scbcman
Default RE: Transmission Trouble?
The tranny problem is not related to your air filter. It's been awhile, since I use a FIPK, but I think you can take the whole stock air box off with a screwdriver. I think there is just one clamp on the bottom of the airbox attaching it to the throttle body. A screwdriver should loosen it. Can't remember for sure now, but it's almost impossible to screw anything up trying to take it off.
Re: Tranny--About the only thing the home mechanic (you) with little experience can do is check the level and condition of your tranny fluid. A low fluid level can cause the transmission to act the way yours is, but it can also cause a lot of damage real fast. Don't do anything without checking the fluid level. Also check the fluid condition. It should be a pink-red and clear, not a brown-red or dirty. If your problem isn't found there, you're going to have to find someone with experience to look at it, and it's gonna cost you a bunch unless you know someone with the experience to service it. Even then, there is going to be expense. Don't worry about your air filter. Get the tranny taken care of first...otherwise the air filter is going to be better used as a paper weight.
