2000 Quad Cab Pass. Door?!!
Old Dec 1, 2006 | 11:36 PM
M.SHANK's Avatar
M.SHANK
Default 2000 Quad Cab Pass. Door?!!
My truck was hit in the front end by some bone head making an illeagal left turn. Its in the body shop now. The passenger door was only scratched a little bit from the front fender being pushed into it. The scratch is not that bad but the door has a little rust on the bottom. I figured I would have the body shop fix the rust at my own expense being that it wouldnt be covered from the accident but they said it would be better to just replace the entire door to insure that the rust would not come back. Then they told me to replace the door and paint it would cost $1,600.00!!! They said the door by itself is $950.00!! Does anybody know where I could find a cheaper door? I have done countless searches and all I come up with is reg. cab doors. HELP!!
Old Dec 1, 2006 | 11:46 PM
timwag2001's Avatar
timwag2001
Default RE: 2000 Quad Cab Pass. Door?!!
go to a junk yard!
someone nailed my truck and i bought the entire bed of my truck for $500 less than what it would have cost to fix it.
Old Dec 1, 2006 | 11:57 PM
M.SHANK's Avatar
M.SHANK
I thought about going to a junk yard but I live in Ohio and most likely any door I would find would probably be in the same shape if not worse. I mite just have to though. Thanks
Old Dec 2, 2006 | 03:56 PM
1980blackfiveoh's Avatar
1980blackfiveoh
try a wrecker in the west coast, or arizona or some place like that. Things don't rust out nearly as fast in dry climates. If you go to a local wrecker you may just get the same problem.
Old Dec 4, 2006 | 03:29 AM
RamOwna's Avatar
RamOwna
i performed a search for your part and received a response from the following company in arizona, hope it helps.. i typed your info as best i could.
"We have the PART that you are looking for. You can call me directly on MONDAY at 516-351-2121.
CHRIS(Five-Star
Auto Recyclers) "
your quad cab door, i assumed it was power... if it helps it helps if not, no biggie right???
