Different Rear axle??
Old Dec 3, 2006 | 08:11 PM
01DodgeRam 1500's Avatar
01DodgeRam 1500
Default Different Rear axle??
I bought a 2001 Ram 1500 5.9L 4X4 SLT Laramie a couple of months ago?
Is there a way I can tell which rear end I have installed (gear ratio).
Old Dec 3, 2006 | 08:19 PM
Socha_62's Avatar
Socha_62
Default RE: Different Rear axle??
Look under the hood theres a sticker that has the ratio on it. 3.55 is stock, 3.92 is option, and if you have an off road its 4.10
Old Dec 3, 2006 | 08:30 PM
01DodgeRam 1500
Checked under the hood, no sticker with any of thouse numbers on it. Also checked the sticker inside the drivers door? any way to tell form looking at the rear end?
thanks for the help
Old Dec 3, 2006 | 09:16 PM
Socha_62's Avatar
Socha_62
Na, all 1500 Rams have the 9.25" rear.
Fill this out and type build sheet in for the subject.
http://www-5.dodge.com/wccsapp/unive...ull&category=R
Old Dec 3, 2006 | 10:28 PM
timwag2001's Avatar
timwag2001
i thought that i remember that there were two tags under the bolts of the rear diff cover on eof which gives you the info that you need.
ive got a sticker inside of my glove box that i think might have it
Old Dec 3, 2006 | 10:40 PM
timwag2001's Avatar
timwag2001
now that i think about it. i may have called the dealer with my vin # and they told me. not to sure though
Old Dec 3, 2006 | 10:42 PM
20dodgeram01's Avatar
20dodgeram01
mine had a sticker right on the axle.. (looking from the back it was on the left side of the pumpkin).. said 3.55 on it
20dodgeram01
Old Dec 4, 2006 | 01:31 PM
JD770's Avatar
JD770
should havea metal tag on one of the bolts.
mine says 3.9=3.92
some say 3.5= 3.55
ect
Old Aug 3, 2008 | 11:30 PM
01DodgeRam 1500
Thanks all it was 3.55
