got hypertech off ebay
Old Dec 7, 2006 | 04:13 AM
ripto's Avatar
ripto
Default RE: got hypertech off ebay
ORIGINAL: HankL
The modified throttle bodies on Magnum 5.2/5.9 V8s usually
improve hp more than you would scientifically predict from the drop in flow restriction
- that is usually a clue
that the ported throttle body is affecting the reading of the MAP sensor
and also leaning the air to fuel ratio for increased power output.
leaning the air to fuel ratio means more air than fuel right? is that the reason behind better gas mileage from aftermarket tb's?
Old Dec 7, 2006 | 11:47 AM
GOD RAM IT's Avatar
GOD RAM IT
ORIGINAL: TMS Bill
You are correct (98+). The PCM counts the pulses and generates speed/mileage data from them given a predetermined tire/gear combo. You have to tell the PCM that you've changed something. My speedometer reads about 2 mph low from just a tire change (285's from 265's).
So if he has a 98 than why is his speed off? If I were him I would be looking somewhere else to fix the speed.
and if the speed is calculated from the tone ring then you dont have to tell the PCM anything. It doesnt care. The only time you have to tell the PCM is when the speed is calabrated from the tranny or other location that wont give accurate speed readings.
Old Dec 7, 2006 | 09:52 PM
Ramdamit98's Avatar
Ramdamit98
ORIGINAL: ripto
if you use the programmer to fix the speedo and then you take the programmer off the truck so its back to stock, will your speedo go back to being off?
When I set my truck back to stock with my Superchips it also puts the speedo back to it previous/stock setting.
Old Dec 8, 2006 | 08:27 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: GOD RAM IT
ORIGINAL: TMS Bill
Because larger tires roll farther at a given RPM but the # of pulses generated by the tone ring (and read by the PCM) doesn't change at that same RPM. You have to tell the PCM that you have larger tires (rolling farther) per revolution. Of course the converse is true as well. Now that I'm thinking of it ... a GEARING change shouldn't affect anything as 1 revolution of the ring gear = 1 revolution of the axle no matter what your ratio is. My mistake ... but a tire change ... absolutely.
