1997 Dodge RAM 2500 Poor Heat
Old Dec 6, 2006 | 05:29 PM
threedodgetrucks's Avatar
threedodgetrucks
Default 1997 Dodge RAM 2500 Poor Heat
I am looking for some advice on a poor heat condition I have. I suspect the blend door but have been unable to find a schematic of the heat duct. The issue is this: Engine operating temp is 200 degrees, new waterpump, flushed radiator and heater core. Both hoses at heater core are hot. I hooked a hooked a hose up to one side of the heater core and check the amount of flow through the heater core. As fast as I could push it in it was coming out. I had the dash partially out and could operate the the blend door. The blend door felt and sounded like it was moving through the full range but I could not figure out how to see inside the duct where the a/c condenser, heater core, and blend door reside. How do I get that assembly apart? Do I have to take it out as unit with heater core and a/c lines disconnected or can I get the top half off somehow? I have a 96 RAM 1500 and the heat works great, the 1997 2500 bad heat and I ahve a 1998 2500 with poor heat...
Thanx,
threedodgetrucks
Old Dec 6, 2006 | 05:37 PM
mojo's Avatar
mojo
Default RE: 1997 Dodge RAM 2500 Poor Heat
It might be screwed it could be glued either way you'll need to take the whole thing out to get it apart. Does the A/C work? It could be the plastic shield between the heater and evap core that is blocking the flow of air.
Old Dec 6, 2006 | 06:01 PM
threedodgetrucks
Thanx for the reply. A/C works fine and it blows great. I didn't know about a plastic shield between the evap core and heater core. Pulling the dash all the way is a bit of a pain, putting it mildly. Do you know of any pics of the inside of the plastic ducting where the evap core, heater core and blend door are?
Old Dec 6, 2006 | 06:32 PM
mntnceguy's Avatar
mntnceguy
For schematics and other info, search this site for the "merry christmas" thread, I think thats what they called it, it is a full manual on our trucks. BTW, if your mode doors are not moving, such as going from defrost to floor via the dash ****, you may have a vacuum problem to the switch. The mode doors are vacuum actuated. And yes, to get the hvac unit apart, ya gotta pull the dash out, and yes, it is a big pita. There are 5 bolts across the top of the dash, 1 on each side, and a brace in the middle bottom. The thing is heavy and awkward, so you'll need a friend. I just disconnected mine to do my heater core, but didn't take it all the way out, used a bunjee cord to hold up the right side enough to pull out the hvac unit. If I remember right, there are 3 vacuum modules on the unit, and 3 mode doors. I would check for vacuum problems first tho, just my .02
Old Dec 6, 2006 | 07:28 PM
threedodgetrucks
Can you point in the right direction to the "merry christmas" manual? I can't seem to find it. Thnx
Old Dec 6, 2006 | 07:44 PM
TMS Bill's Avatar
TMS Bill
Click here: https://dodgeforum.com/m_340929/tm.htm
Big D/L.
Old Dec 6, 2006 | 07:59 PM
threedodgetrucks
Absolutely outstanding!
Many thanx,
