new ac clutch noise
Old Dec 8, 2006 | 04:54 PM
Morgans01RAM's Avatar
Morgans01RAM
Default new ac clutch noise
I had to replace the ac clutch and compressor this summer. ac works fine now, however it makes a sound that sounds simmilar to a turbo spooling up under acceleration and deceleration. around 2000 rpm it does not make this sound.
Old Dec 8, 2006 | 05:25 PM
mntnceguy's Avatar
mntnceguy
Default RE: new ac clutch noise
Sounds to me like the clutch is not shimmed right. Need to know when the noise happens. Is it when the A/C is on, and the clutch is engaged, or when the A/C is off. If it happens when A/C is running, its compressor bearings, and you don't have enough oil in the compressor. If its when its off, your clutch is not shimmed correctly. Either way, I wouldn't be running it much till you get it fixed, both problems mean your gonna be spending more money soon, [sm=icon_stickpoke.gif]
Old Dec 8, 2006 | 05:39 PM
Morgans01RAM
It takes place with the ac off but I dont recall if it does this with the ac on. Ill check in a bit and get back
Old Dec 8, 2006 | 09:21 PM
Morgans01RAM
Really odd I drove to class this afternoon and it made the same noise with the ac on. which do you think it is the shim or fluid or both.
Old Dec 9, 2006 | 06:00 AM
mntnceguy's Avatar
mntnceguy
Neither, its gotta be something else. Belt noise, air leak, power steering whine, can't say for sure w/o being there, but highly doubt its the compressor. The compressor would change a noise when it is on/off. I would have to ask if you have a V-belt, or serpetine belt? A V-belt riding in the bottom of the pulley ( not being tight enough) would cause that kind of noise, but other than that you'll have to spend a little more time finding the exact cause of the noise. Hope that helps, otherwise, good luck [sm=deal.gif]
Old Dec 11, 2006 | 05:57 PM
Morgans01RAM
got it fixed it was a throttle body gasket.
https://dodgeforum.com/m_634358/tm.htm
thansk for the ideas
