odometer reads no bus
Old Dec 10, 2006 | 05:59 PM
mcgilljd's Avatar
mcgilljd
Default odometer reads no bus
went out this morn to start my 2000 dodge ram 1500 4x4 truck and i seen that none of my gauges was working my engine ,abs. airbag and low fuel lights was all on and the odometer reads no bus can someone give me some help thanks...david
Old Dec 10, 2006 | 06:01 PM
20dodgeram01's Avatar
20dodgeram01
Default RE: odometer reads no bus
somethings up with the computer in the truck.. i'd get it looked at
Old Dec 10, 2006 | 06:41 PM
dhvaughan's Avatar
dhvaughan
depending on whether it starts or not, and how much patience, time and money you have... do a search on 'no bus' in the 2nd gen forum. There are a lot of posts. some report simple unplugging and replugging a power connection as a fix, others more extensive computer or instrument cluster replacement. Just for information in case it is something with instrument cluster, i bought one on ebay for $25 to fix a speedometer problem. Here's a cut/paste from the power connection post....
good luck, doug
MacsRock
I have had this problem on my 2001 V6 several times and always came and went but always ran fine, just the gauges where all dead. I would always restart and it would go away or disconnect connectors to the ECU and clean all the grounds under the hood and it would go away. Well this time it would not go away and so I did the usual stuff and still had the problem. Finally found this time it was the electrical connector called Engine Inline in the fuse box under the hood, it has a philips head bolt in the center of it. Just disconnected and reconnected and the gauges all work now.
Charles
2001 Ram 1500 V6
Old Dec 10, 2006 | 11:08 PM
mcgilljd's Avatar
mcgilljd
the truck starts fine nd runs fine it has done this 2 times once on 12-10-06 and the other was about 6 mouths ago this time i removed the neg battery terminal and it fixeg it this time the time before it just quit all on its on thanks for all the help i dont know if it has anything to do with it or not but i have alot of emergency equipment on this veh. thanks for all the help
