Differential Help!!! please
Old Dec 14, 2006 | 01:30 AM
jktrepin's Avatar
jktrepin
Default Differential Help!!! please
My Differantial gasket is a lil messed up and i want to put a new chrome cover on it anyways but i was wondering... do i just unbolt the cover, drain the fluid, but how do i get fluid back in the differantial??? it might be a stupid question but i dont want to mess anything up. And how do you find out what differantial you have?? I have a 98 1500 5.2L 4x4..... any help is great!!!! Thanks
-Jake-
Old Dec 14, 2006 | 01:36 AM
TMS Bill's Avatar
TMS Bill
Default RE: Some Help please!
Your rear diff is a Chrysler Corporate 9.25" ... the front is a Dana 44. You refill the diff after reinstalling the cover. Make sure the cover you get has a fill hole.
Old Dec 14, 2006 | 03:04 AM
timwag2001's Avatar
timwag2001
your dif cover should have a plug in it. the dif fluid should reach the bottom of the plug hole
Old Dec 14, 2006 | 04:11 AM
jakebrake's Avatar
jakebrake
I've never used a gasket on diffs before, always just used black or red rtv. How much horse power will that cover add???[sm=joke.gif]
Old Dec 14, 2006 | 12:49 PM
Socha_62's Avatar
Socha_62
I agree, get a tuve of RTV. Cost the same as the gasket, or cheaper and you'll have tons left to use of other stuff.
Old Dec 15, 2006 | 02:20 AM
jktrepin's Avatar
jktrepin
i want the cover cause mine now looks like ****. The new cover costs about 25 bucks. I was just making sure... Thanks,
Old Dec 15, 2006 | 03:07 AM
jktrepin's Avatar
jktrepin
I cant find anything for the Chrysler Corporate 9.25" ......... The only covers i can find are for a Dana 40 and and Dana 60. Is the Chrysler 9.25 the same as one of those ??? I just dont want to mess anything up.
Old Dec 15, 2006 | 08:45 AM
dodgeman881's Avatar
dodgeman881
First off you should check b/c some of the Dodge's had a 8.25 and a 9.25 Chrsyler rear end. Look in your glove compartment I believe it may tell you what kind of rear end you have. Don't search for a Corporate Axle, b/c it will probably come up wrong. I picked up a cover for my 01 Ram from Accuautoparts.com, it was about 40 bucks with shipping. Also, I used RTV sealer it is cheaper and a lot easier to clean up if you have to go back in the pumpkin.
Old Dec 15, 2006 | 05:19 PM
Tani1500's Avatar
Tani1500
the only axles that came in rams is either the corp. 9.25 or a dana 60, dana 70, or dana 80. 1500's came with 9.25, the 2500's came with either a 9.25 or dana 60, dana 70, 3500's had the dana 80 the 9.25 and dana 60 are every differnet axles. the dana 60 cover looks just like your front axle cover, just larger. the 9.25 looks like a stop sign
