-96 Ram 1500,Mirror problem.
Hi guys.
Just moved into the country from Sweden, i have always liked the Dodge for its look and performance, so when we came in 2 weeks ago i picked up a -96 Ram with only 70k miles on it,probably paied way to much for it also but i needed a hand hauling our boxes we had to take out of the airport. So anyway, the rearwiev mirrors are acting weird, they are totally loose and are flopping in the wind when you are driving,and if i get on the freeway the wind makes them turn against my side windows,this is really irritating and also dangerous. I´ve crawling around trying to figure out how they are mounted on the door but i cant find a single screw or anything to hold them?! I´m sure you guys know what i´m talking about,what should i do to fix this!? Thanks! |
RE: -96 Ram 1500,Mirror problem.
Big problem with those 96 model mirrors..You can take the door panel off and there will be 3 bolts that holds the mirror on.I to had the same problem with my 96.I went to the salvage yard and pulled them my self and got a pair off of a 99 model.Much better mirror and no more problems.There is really no way to actually tighten the mirror on your model,pick you up some newer ones for really cheap,hopr this helps,
Ramblin |
I had the same problem. Thanks for the tip. They'll go by the way side if they get lose again.
Thanks for the reply.
That sucks that it is a common problem, anyway, any idea what they might cost? I have electric adjusting on them to, will that be able to have on the -99 model mirrors also or do they need to be modified? Anything more i can do to get this truck a little bit faster? The stock exhaust dosent really seem like the breather kind. Is there any after market systems to get? I already read about the air, that a K&N will make it better. |
ORIGINAL: Ramblin Big problem with those 96 model mirrors..You can take the door panel off and there will be 3 bolts that holds the mirror on.I to had the same problem with my 96.I went to the salvage yard and pulled them my self and got a pair off of a 99 model.Much better mirror and no more problems.There is really no way to actually tighten the mirror on your model,pick you up some newer ones for really cheap,hopr this helps, Ramblin |
it is worth reading this TSB
http://dodgeram.info/tsb/1998/08-09-98.htm from this very useful Dave Fritz webpage http://dodgeram.org/tech/troubleshoot/body.htm |
