Steering gear box install help
Old Dec 23, 2006 | 07:24 PM
Eric334's Avatar
Eric334
Default Steering gear box install help
I have to replace my steering box, I know my way around a truck pretty well and have plenty of tools but I've never done this. Is there anything that I need to know that I might run into? any advice will be taken.
Old Dec 23, 2006 | 07:52 PM
arty's Avatar
arty
Default RE: Steering box install help
i can not help you but i am interested what other people will say i hit a stone wall a few years back and my steering wheel is out of whack my cruise control is at the 12 o clock and 6 o clock position instead of being at the 3 and 9 o clock i was told i need a new steering box thanks
Old Dec 23, 2006 | 09:14 PM
DADDIEMIKE's Avatar
DADDIEMIKE
Default RE: Steering gear box install help
PRETTY EASY JOB TO DO JUST DID MINE TODAY . REMOVE THE TO PRESSURE LINES ON TOP AND REMOVE THE PITMAN ARM AND THEN THE THREE MOUNTING BOLTS. ASSEMBLE IN REVERSE ORDER AND FILL WITH STEERING FLUID TURN FULLY TO BOTH SIDES TO BLEED OUT AIR AND CHECK LEVEL. 1- 1.5 HR. JOB IF YOUR MECHANICALLY INCLINED.
Old Dec 23, 2006 | 09:23 PM
GOD RAM IT's Avatar
GOD RAM IT
the truck should be jacked up and not running when turning the steering back and forth to get the air out.
add fluid as necessary
Old Dec 23, 2006 | 09:39 PM
radwebster's Avatar
radwebster
go rent a pitman arm puller from autozone. its free, you just gotta put down a deposit. makes life easier.
also, while the box is out, do NOT cut the wheel any further than you would normally turn it. if you do,m you will rip your airbag wiring harness out. i know...
Old Dec 23, 2006 | 10:46 PM
Scottr1110's Avatar
Scottr1110
lol i know about that one to sucks
Old Dec 24, 2006 | 05:29 PM
GOD RAM IT's Avatar
GOD RAM IT
Also. I would bungy the steering wheel to the seat so it doesnt move and ruin your claock spring
