Knock Sensor Location?
Old Dec 25, 2006 | 12:39 PM
Aubrey's Avatar
Aubrey
Default Knock Sensor Location?
Does anyone know where the knock sensor is on a 95 5.9L? I get bad knock in the summer and thought I'd replace it just to make sure it was working correctly. They have to be pretty cheap and easy to replace. - Thanks and Merry Christmas
Old Dec 25, 2006 | 02:24 PM
dsertdog56's Avatar
dsertdog56
Default RE: Knock Sensor Location?
The reason you can't find one is that Dodge doesn't use them. If you've got a knock issue, you need to check some other things. Part of your hot weather spark knock is a combination of high intake air temps, low octane fuel, and too much spark advance, or too quick of an advance curve in your PCM.
Hughes engines sells a pretty slick add on unit.
http://www.hughesengines.com/partDet...amp;eTypeID=10
Old Dec 25, 2006 | 08:53 PM
Aubrey's Avatar
Aubrey
I thought the PCM automatically adjusted the advance for knock. That's why I was looking for a sensor. Would just a Mopar Performance ECU cure it too? But that's premium fuel all the time I believe. - thanks
