squeak fixed - auto trans shifter linkage
Old Dec 30, 2006 | 10:28 PM
dhvaughan's Avatar
dhvaughan
Default squeak fixed - auto trans shifter linkage
this has been driving me crazy. it had 2 different noises. when you shut the drivers door it would sort of rattle under the truck, about where the suspension arms are. when you drove slow, it was a sort of deep squeak. at a dead stop it would sometimes squeak and sometimes not. it squeaked more in Drive than it did in Park. when you got out by yourself and try to find it, it would always quit.
just by accident, while closing the hood, i gave it a side to side wiggle and got it to squeak. so i got my son to wiggle it while i crawled around underneath. A-HA. there is a horizontal rod that is part of the shifter linkage that has plastic looking bushings at each end. ERK ERK ERK ERK ERK ERK. white litium grease grease grease and now....... quiet..... ahhhh !
hope this helps someone.
doug
Old Dec 31, 2006 | 12:19 AM
gta91's Avatar
gta91
Default RE: squeak fixed - auto trans shifter linkage
I have had a similar noise in my truck, since brand new..
I am not sure if I would discribe it as a squeek, or a quick rattle.. But I only hear it sometimes. Mostly while in park, and when the vehicle is not moving...
As you stated, I tried to get out of the vehicle to hear the noise, and it would go away..
I am going to look at that linkage you discribed this eve...
I wonder why I have been hearing this since new though... and again,, seems more like a quick rattling noice, or quick clunking noise..
I can in no way recreate this, it just happens when it wants.. I try to troubleshoot.. and it goes away..
Anyway... I will check the linkage..
Karl
Old Oct 31, 2007 | 08:46 PM
CopperDesigno's Avatar
CopperDesigno
I have the same issue that dhvaughan describes, I think? I white lithium greased the hell out of it and it still squeaks in anything but Park, and sometimes in park. I noticed I was missing the wave washer for the rear shift rod.
I spent over $300 trying to solve this squeak, mostly new belts, pulleys, and tensioner, even had a shop stethoscope the front of the motor to find the squeak. The shop replaced the belt, number 3 in a month.
I don't think its the belt, the squeak doens't change pitch or speed as the motor RPMs change.
My only other thought on this is that it could be the fan clutch assembly. The fan wiggles back/forth a little, but I have no clue if that's normal.
What am I missing????
Old Oct 31, 2007 | 10:48 PM
CopperDesigno
Can I take the engine fan off and run the engine for a couple minutes to see if that's the squeak?
Old Oct 31, 2007 | 11:33 PM
aim4squirrels's Avatar
aim4squirrels
You can run it without the fan, just watch your coolant temp.
Old Nov 1, 2007 | 04:23 AM
kstroeher's Avatar
kstroeher
Mine had the steering squuek since new too. Luckily my dealership knew where to look right away and fixed it. Whatever they did seemed to have fixed it permanantly.
Hey Copper, you should not be able to wiggle your fan like that, sounds like you need a fan clutch.
Old Nov 1, 2007 | 07:02 AM
CopperDesigno
Thanks guys. I don't need to run it ong without a fan, just to verify the squeak is gone or not.
