problem with front end on 2000 4x4
Old Dec 31, 2006 | 09:32 PM
phrogs's Avatar
phrogs
Default problem with front end on 2000 4x4
Ok the wifes truck a2000 dodgeram sport extended cab4x4 has started to make a nice clunk noise up front, has some vibration that comes into the cab, I drove it and its worse when you turn almost felt like the rotor might be the culpret or a u joint.
I jacked the truck up and the offending side is the RH
with the wheel still on I can pull up and down on it and push the entire assymbly in and out of the axle,
Im thnking its a bearing in the axleWhen I removd the tire I could see the yokethat attatches to the the steering knuckle is visually moving up and down and in and out when I move it so it seemsthatsomething internal to the axle is jacked up.
Also the LH side is nice and solid no movment at all.
I havent pulled one of these apart in a long time and I do not have a manual for the truck Ima corvette guy so im used to half shafts independantsuspensionsand dana 44s on a car!
Dont hate me because I have corvettes
anyway any help on this is appreciated maybe someone canpoint me in the right direction and whats a good manual for these? I buy the GM shop manuals for the vettes id like to get something like that for the truck any idea where I can get one?
thanks
johnny
Old Dec 31, 2006 | 09:47 PM
bamory's Avatar
bamory
Default RE: problem with front end on 2000 4x4
Here ya go, Happy New Years, may not be the same truck as yours but the concept is all the same.
http://www.pavementsucks.com/tech/hub.php
Also check out the Merry Christmas thread, possibly at the top of the main page.
