o2 sensor
Old Jan 2, 2007 | 12:48 AM
roosterex's Avatar
roosterex
Default o2 sensor
I am new here I have a 98 ram 2500 with a 360 90k the problem I am having is within the last 1k miles Ihave went through 6 o2 sensors. The truck will be running fine the engine light comes on up stream code comes up first within 20 miles the downstream pops up. any help would be greatly appreciated. I have had truck at the dealership, they had it for 2 days and could not find anything. I am using bosch sensors Thanks
Old Jan 2, 2007 | 01:56 AM
steve05ram360's Avatar
steve05ram360
Default RE: o2 sensor
welcome to DF... check for a o2 heater fuse and see if its blown. my 2000 had one and blew when the wiring shorted and grounded the heater element. this caused some intermittant bucking.
Old Jan 2, 2007 | 05:16 PM
roosterex's Avatar
roosterex
I checked the fuse it is in good shape. could i have a bad spark plug causing the sensors to go bad
Old Jan 2, 2007 | 05:25 PM
topsites's Avatar
topsites
I am thinking you might have a bad sensor sensor, meaning the stupid light inside the truck is coming on when it shouldn't..?
Unplug the light bulb and your problem is fixed
