Bypassing od off light, which wire to cut?
Old Jan 2, 2007 | 07:20 PM
IndyRamMan's Avatar
IndyRamMan
Default Bypassing od off light, which wire to cut?
Im installing a LED pannel for my indicator lights. Im trying to figgure out which wire to cut for the light that shows the overdrive off switch has been pushed.
I have a wireing diagram from dodge, but its a little confusing for me as I am no electrician. There are 5 prongs for the harness.
Point 1 goes to the transmission overdrive switch sense...im assuming thats not it
Point 2 goes toG202...im assuming its a ground wire.
Point 3 goes to Joint Connector C...im assuming thats the activation for the light, and my current pick as of now.
Point 4 goes to a Fuse Block, and branches off to the Fog Lamp Switch.
Point 5 goes to C133 and branches off to "upshift lamp" (but that says its on the instrument cluster for manual trans)
Points 4 and 2 are opposite eachother with Illumination Lamp in the middle and point one connecting into them inside the block.
Points 3 and 5 are opposite eachother with On Indicator in the middle .
which wirte to cut?
Old Jan 2, 2007 | 07:38 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: Bypassing od off light, which wire to cut?
nm, its the one i thought.
Old Jan 2, 2007 | 08:04 PM
timwag2001's Avatar
timwag2001
do you have a pic of your led panel? what did you pay for it?
i currently have my dash apart and im looking for a new panel.
Old Jan 3, 2007 | 12:28 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: timwag2001
custom making it.
for now im just adding leds where i felt they should have gone from the factory. Today was just blue 7/32" leds over top the OD/off switch and the fog lamp switch. They look very awesome if I do say so myself, and i do.
