Glowing hot bolt on alternator
Old Jan 3, 2007 | 02:05 PM
Dirtylittlesmurf's Avatar
Dirtylittlesmurf
Default Glowing hot bolt on alternator
On the back left corner of the alternator there is a bolt comming out, a black copper wire attaches to that. Well gages were reading low voltage so I checked it and the wire was loose. I pulled it out and was looking at the connection, the bolt had gotten so hot that it fused with the fastner on the end of the copper wire. I knocked off the excess slag and put it back together, I jump started it and I checked the connection and the bolt was glowing, super hot.
So what should I do to remedy this? new bolt? new alternator?
Thanks.
Old Jan 3, 2007 | 03:28 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Glowing hot bolt on alternator
That's a ground. Something is not right if the gauges are reporting low voltage and the bolt is red hot.
Old Jan 3, 2007 | 03:47 PM
Glideman88's Avatar
Glideman88
Sounds like a winding or diode shorted to the alternator case and then shorting out through the ground wire.
Old Jan 3, 2007 | 10:55 PM
timwag2001's Avatar
timwag2001
i dont know what year your truck is but there is a recall for 2001 about loose alt wires. check it out
