Weird Popping Noise while turning.
Old Jan 3, 2007 | 09:47 PM
matt62557's Avatar
matt62557
Default Weird Popping Noise while turning.
Hey guys, so i have the 95 ram 1500 4x2 laramie package....and when make turns i hear a popping noise and i can feel it under my left foot...kinda like somethings hitting the bottom side of the floor board. I noticed this when i bought the truck, but it wasent as bad. Its gotten a little bit worse....also i was wondering if it could be the running boards or my seat mounts or anything.
Another thing... when i put the truck in drive and take off real slow, i can hear a grinding noise, but when i take off fast i only hear it for a second...maybe like a tight spot or something? Or could it be a heat shield vibrateing? Its starting to concern me...
thanks guys
Old Jan 3, 2007 | 11:06 PM
rango726's Avatar
rango726
Default RE: Weird Popping Noise while turning.
as to your grinding noise it sounds to me like your universal joints is it consistent with your trucks speed ?.does it go away at higher speeds? and the clunking sounds like a radius arm bushing.maybe a ball joint or tie rod
Old Jan 4, 2007 | 12:15 AM
CopperDesigno's Avatar
CopperDesigno
If it feels like its at your feet, then I would check the control arm bushings. I just made an appointment to have new control arms put my truck today. When I turn left it sounds like crunching/popping from under my left foot.
