Torque Specification
Old Jan 4, 2007 | 02:13 AM
NOMORECHEVY's Avatar
NOMORECHEVY
Default Torque Specification
Just replaced the oil pan gasket in my truck and my friend said I need totorque the bolts up to200 (in-lbs) [sm=smiley25.gif]WOW!!! Does anybody knows for surethe Torque Specifications (in-lbs)for the oil pan bolts/studs on a 1998 Ram 1500 V8 (5.2L) in order to prevent oil leaks? Is my friend correct about the torque specification?
Old Jan 4, 2007 | 02:48 AM
timwag2001's Avatar
timwag2001
Default RE: Torque Specification
yeah... 200 is what it calls for
Old Jan 4, 2007 | 03:37 AM
johnalm's Avatar
johnalm
1/4 air ratchet has never failed
Old Jan 5, 2007 | 02:01 AM
zosoaol's Avatar
zosoaol
Make sure your torque wrench reads inch pounds not foot pounds. Of course you'd figure that out after you twisted the first bolt off.
Old Jan 5, 2007 | 10:03 PM
NOMORECHEVY
That's a good point, thanks! You can alsomake the conversion.....1FT-LB = 12 IN-LB
