I'm back!!!!!!!!!!!!!!
Hey boys, sorry for the hiatus, but work and vacation have been crazy...whats new...
And by the by---I need a transfer case for my beast....anyone out there have a line on one, preferably 231hd...
Kyle
Kyle
Check out these specs on transfer cases, and reconsider getting a 241 instead (or the 241HD if you want a PTO).
http://dodgeram.org/tech/specs/tranfer_case.htm
If it's going on the truck you have previously posted pictures of, then you should get the stronger transfer case because that truck is huge. The 231HD is basically the same as the 231D and the 231J , which is the standard t-case on Jeeps I think you will want something a little stouter for your rig.. The 231HD just has a wider chain then the 231D and 231J. The 241 is far better suited for your size truck.
welcome back
