truck does not like 4 low
Old Jan 6, 2007 | 06:07 AM
ddog737374's Avatar
ddog737374
Default truck does not like 4 low
my truck seems not to like 4 low always poping out when trying to pull poeple outor even driving around is their any reason its doing this?
Old Jan 6, 2007 | 06:06 PM
Ram1500Dodge's Avatar
Ram1500Dodge
Default RE: truck does not like 4 low
you sig says you have 6 inches of lift. is any of that lift body? if so, when you put the body lift on, did you readjust the t-case linkage?
Old Jan 6, 2007 | 06:26 PM
thump186's Avatar
thump186
It sounds like a linkage adjustment like Ram1500 suggested.
Old Jan 6, 2007 | 06:58 PM
ddog737374's Avatar
ddog737374
YeaI do have a body lift andI did add the 3 inch linkage thatI hadto weld to the t-case linkage is their anything i can readjust with out cutting?
Thanks Dan
Old Jan 6, 2007 | 09:57 PM
Tani1500's Avatar
Tani1500
there should be a lever coming off the top the the tcase, theres a bolt on it. unbolt that and move it in the direction it needs to go
Old Jan 6, 2007 | 10:17 PM
ddog737374's Avatar
ddog737374
Rock on thanks guysI thinkI fixed it.
Old Jan 7, 2007 | 03:15 AM
Ram1500Dodge
just out of curiousity, when i put my 3 inch BL on, i didnt have to weld the extension to the t-case linkage, i remember just adjusting it. did anyone else weld the extension on?
