Cyl 4 misfire...expensive
Old Jan 7, 2007 | 12:40 AM
dflyboy's Avatar
dflyboy
Default Cyl 4 misfire...expensive
Well here I am again with yet another costly fix. My CEL came on and went off and them came back on. On my way home for christmas I noticed my truck was loosing power and just not running like it should. I took it to a shop when i got to my hometown and it gave a code of Cyl 4 misfire. I THOUGHT oh that should be easy to fix...either sparkplug or wire... I went into the city, had some beers andmade a new friend with a guy that had a garage and he insisted on looking at it. He diagnosed a bad Exhaust Valve on at least 2 cylinders. I was bummed but told him to fix it. In the end I did have bad Valves... BUT my Heads were both cracked in 4 places.After all said and done a few other things needed fixed and a lot of money was spent. Wasnt a good Christmas needless to say.
I was very impressed with the Repair shop I was at and if anyone is in the Lethbridge, Alberta, Canada area make sure you go to North Side Auto... you wont be dissapointed. I live 5 hrs away and I will make the drive to go there to get my truck worked on, as long as it allows me too.
Old Jan 7, 2007 | 01:25 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Cyl 4 misfire...expensive
Are you getting the heavier duty aftermarket cast iron heads? I did, and I went with beefier valves. Truck runs like a raped ape, and I love it.
Old Jan 7, 2007 | 02:27 PM
timwag2001's Avatar
timwag2001
ORIGINAL: VWandDodge
you'ld think that if the one who did the raping really did it good, the ape would probably limp away
Old Jan 8, 2007 | 01:23 AM
rango726's Avatar
rango726
dfly im dealing with the same thing just bought an 02 2500 and it couldnt pull my 1300# enclosed trailer so i brought it back to the dealer and they told me stuck exhaust valve until they took the heads off. and there all cracked. i wish i was aware of the cast iron heads that vw is talking about i would have split the difference with the dealer oh well when it rains it poors. i guess thats life
