5.9 HD?
Old Jan 8, 2007 | 06:53 PM
Spiker's Avatar
Spiker
Default 5.9 HD?
Howdy,
I decoded the VIN on my truck the other day and according to that my truck is equipped with the 360HD. I'm assuming that means heavy duty. If so, what makes it more heavy duty than any other 5.9?
Thanks!
Spike
Old Jan 8, 2007 | 07:21 PM
shott8283's Avatar
shott8283
Default RE: 5.9 HD?
im curious on how you came up with the HD part..
Old Jan 8, 2007 | 09:43 PM
Spiker's Avatar
Spiker
Default RE: 5.9 HD?
http://dodgeram.org/tech/specs/VIN_decode.htmis how I found out. I'm curious about what parts may be different.
Old Jan 9, 2007 | 12:58 AM
01OffRoadster's Avatar
01OffRoadster
Default RE: 5.9 HD?
The only differance I know is the HD 5.9L that comes in the 3500 has an air pump. The internals are all the same.
Old Jan 9, 2007 | 04:23 PM
HankL's Avatar
HankL
Default RE: 5.9 HD?
The HD version had:
air pump driven off the engine,
twin catalytic converters (better flow)
bigger muffler,
made its torque peak at 2800 rpm rather than 3200 rpm.
Old Jan 9, 2007 | 06:47 PM
Spiker's Avatar
Spiker
Default RE: 5.9 HD?
Thanks for the info. Turns out I was a digit off anyway. Just a regular old 360 in the Ram afterall. Checked again because the exhaust is factory and it only has one cat on it. Thanks again!
Spike
Old Jan 10, 2007 | 12:47 AM
JarheadX's Avatar
JarheadX
Default RE: 5.9 HD?
lol my muffler was soooo f'n huge when i took it off, such a waste
Old Jan 16, 2007 | 02:17 AM
jasont415's Avatar
jasont415
Default RE: 5.9 HD?
My friends 360 LD had 318 heads on it, we dont know if it was a previous owner that did it, but when we were checking specs on the valves, all the specs on the heads were from the 318, idk if thats a difference in alot of them but...
