1995 leak issue
Old Jan 8, 2007 | 09:31 PM
spmyers's Avatar
spmyers
Default 1995 leak issue
I just bought a 1995 SLT STD Cab Short Bed. Lifted 6' sitting on 35" Toyo M/T, I drove it home the other night in a huge downpour and went out to the truck today and noticed a fairly large wet spot on the passenger side floor. I crawled under it and couldnt find anything wrong... there are no other leaks, it couldnt be the windows or doors I checked.Let me know if you have any ideas. Thanks
Old Jan 8, 2007 | 10:05 PM
mopar98's Avatar
mopar98
Default RE: 1995 leak issue
Do you have anything mounted to the roof like a visor or cb antenae or after market cab lights .
Those can cause a leak pretty quick.
Also is there a chance it's not water and it's antifreeze .
When the heater core goes out you'll end up w/ a puddle of antifreeze on the floor.
Let us know what u find.
Old Jan 8, 2007 | 10:14 PM
DieselDemon's Avatar
DieselDemon
If you're not leaking coolant from the heater core, then definitely check your third brake light. Water gets into it and runs to the passengers side of the floor. I have read several threads about this. Guys simply unscrew the third brake light and apply silicone around it.
Good luck with your ride.
Old Jan 8, 2007 | 10:35 PM
spmyers's Avatar
spmyers
I dont think itscoolant,but im not sure. How would I know? I soaked it up and it was clear and didnt have any smell oranything.I will have to go out and dick around with the brake light.
Old Jan 8, 2007 | 10:48 PM
morrgriff's Avatar
morrgriff
I have a '99 and when I bought it, the A/C's fan housing was cracked and caused water on the floor whenever the A/C was used. Look under the glove compartment area. It's a bit prone to getting kicked and such if it was a work truck. I used some plastic epoxy after roughing the area up w/ sandpaperand has worked for three months now.
Just another idea.
Old Jan 9, 2007 | 05:19 PM
DuranguenzeRam's Avatar
DuranguenzeRam
Try the third brake light mine was dripping siliconed her up and not a single drip no more
Old Jan 9, 2007 | 05:54 PM
spmyers's Avatar
spmyers
Ok so I havnt driven the car since yesterday. just went out and checked it and it is still pretty wet, more wet than I left it last night. So it cant be coolant or the AC unit. None of the doors or windows is leaking. I need to try the third brake light. any other ideas?
Old Jan 9, 2007 | 06:04 PM
timwag2001's Avatar
timwag2001
did you look at the windshield? check the rubber that goes around it. how about the weather stripping that seals the door to the cab?
