Cracking on the drivers door?
Old Jan 8, 2007 | 11:23 PM
mopar98's Avatar
mopar98
Default Cracking on the drivers door?
Is this really that common on almost every Dodge that I have worked on including mine the bolts that hold the window trac have cracks around them and sometimes the bolts have pulled through anybody else notice this . So far I've had to either put larger washer's on some guys trucks or weld the cracks back up. One guy had a 6 inch crack running all the way to the to the locking mech. I've seen this on the 95 to the 99 . You'd think DC would have seen or heard about this and done something to fix it.
Old Jan 8, 2007 | 11:55 PM
Buzz's Avatar
Buzz
Default RE: Cracking on the drivers door?
Mine cracked so bad the boltwould not hold the track.I used a fender washer to tighten it up
