96 V10 Low Idle
Old Jan 11, 2007 | 02:26 PM
pipedreams's Avatar
pipedreams
Default 96 V10 Low Idle
My 96V10 has recently started to idle really low............600 rpms or so? Nothing has changed that I'm aware of and it seems to run fine other than this. The big problem is when you come to a stop it stalls. Is there any way to adjust the idle back up to a normal RPM without all kinds of diagnostic tools? Like an old time "idle adjustment" hopefully?
Thanks
Old Jan 12, 2007 | 06:45 PM
landarch96's Avatar
landarch96
Default RE: 96 V10 Low Idle
my '01 v10 was running rough and idling low.....set of plugs/wires and some throttle body cleaner did the trick. don't know if it's the same problem you're having but it might be work a shot since its cheap.
