Oil PSI?
Mine stays a complete needle's width past the 40 mark, but I run Synthetic motor oils and it gets changed regularly.
Actually, it currently has Kendall's synthetic blend in it, 10w-30 grade.
Safe to say thou, 40+
ORIGINAL: RM_Indy
Tad over 40 stock, 44-45 if I remember correct with h/v pump (stored for winter if it ever comes?)
im guessing my oil pump may be dieing then. Whill the oil pump slowly degrade over time, rather than suddenly die?
Trending Topics
40 is a very good number, now if it drops to like 10-20 I would be a little worried, of course you will probably see higher pressure the newer your oil is, as it gets older and thinner it doesnt keep pressure as well. Also If your going by just the dash guage, it could be off some, maybe hooking up an actual oil pressure guage will tell a different number
Not to Hijack the thread,But what wieght Rotella do you use?I use the 15-40w in my Wrecker now.I was highly considering using it in the dodge.I use standard oil in it now and 1 quart of lucas.My pressure is great.But I think I could benefit from Rotella.
wow.. i'm using royal purple right now (long story well sorta but cool at the same time) 10-30w and it's cruising at about50 and idling at 35. it used to idle at 40 and cruise at 50 with the napa synthetic.
