High Performance Tune-up
Old Jan 14, 2007 | 12:13 AM
dustrunner03's Avatar
dustrunner03
Default High Performance Tune-up
Has anyone found or heard of a combo or match of products for plugs, wires, cap, etc...
im gonna be doin a tune-up soon and need some input.
Old Jan 14, 2007 | 12:23 AM
974x4's Avatar
974x4
Default RE: High Performance Tune-up
http://www.truckperformance.com/prod...500/318%7E5.2l
Old Jan 14, 2007 | 01:05 AM
padodgeram's Avatar
padodgeram
I use MSD coil ,MSD wires 8.5..spark plug autolite , cap and rotor from napa the cap make sure its brass
Old Jan 14, 2007 | 01:48 AM
Silver_Dodge's Avatar
Silver_Dodge
Saw this on another forum the other day, but don't know of anyone who has tried it:
http://www.performancedistributors.com/dtrkignition.htm
Otherwise, Mopar makes a kit that includes cap, rotor, and plug wires. It is basically OEM replacement parts though.
Old Jan 14, 2007 | 02:13 AM
shott8283's Avatar
shott8283
id like to see a dist. cap manufactured and sold to mimic the LS1 style caps that are flat and have the plug posts horizontal instead of vertical.. and its set up so that the 4 cyl. are on the one side and the other 4 are on the other side.. cleans it up rreally nice and ensures that you dont have to cram the damn wires in there to make them fit.
anyways
i was really happy with my MSD setup.. another good tuneup trick is to remove your O2's and clean them... and to switch to syn. oil. in all your fluids (diff, tranny, tcase, crankcase etc etc) i have a write up in the DIY thread on my msd setup if you wanna take a look-see.. i mention in there buying the correct msd coil as some coils have a difference in input resistance and have a tendency to **** off the PCM .. and can burn it out..
heres a shortcut.. https://dodgeforum.com/m_405881/tm.htm
the blaster 3 is choice when looking for a MSD coil..
Old Jan 14, 2007 | 03:15 AM
topsites's Avatar
topsites
This is what I use:
Autolite Double Platinum plugs (Bosch works also, the secret is double platinum).
Accel cap and rotor
Taylor 8.2mm wires (accel works also, the trick to remember is EIGHT mm's).
Mallory coil
Kendall Synthetic racing blend 10w-30 motor oil.
(but most any brand synthetic blend will do, it's all high performance so long it is a synth).
Old Jan 14, 2007 | 03:32 AM
timwag2001's Avatar
timwag2001
bosch double platinums?!?! no!!! no good.
Old Jan 14, 2007 | 04:36 AM
akyne's Avatar
akyne
Platinum, double platinum, iridium, triple uranium, weapons grade plutonium, or whatever other precious metals they're deciding to put into spark plugs these days are no good in the magnum engines. You need a simple copper plug with a single electrode and preferably one with a temperature rating slightly cooler than comes stock with the trucks. Autolite 3923's come to mind. Anything fancy can lead to detonation.
Old Jan 14, 2007 | 03:09 PM
1996Ram318's Avatar
1996Ram318
About 30k miles ago, I did a tune up with Accel extreme 9000 8mm wires, cap, and coil. Well, the coil lasted about 5k miles before frying, but I have been happy with the wires and cap.
I also run Bosch platinum +4 plugs, and they run just fine in my 5.2L.
