No start what should I check first
Old Jan 15, 2007 | 12:53 PM
nateblong's Avatar
nateblong
Default No start what should I check first
Hi my managers 00 ram wont start.this morning andits not throwing any codes, full tank of gas, fuel pump kicks on when key is turned. and it cranks strong, but wont sputter or anything. What are some obvious things to check. I know fuel and spark, but is their anything to check first. truck ran fine when parked last night. its a 360 ...5.9 with auto. Thanks alot
Old Jan 15, 2007 | 02:02 PM
JarheadX's Avatar
JarheadX
Default RE: No start what should I check first
well yeah, plugs wires ur obviously not getting spark
Old Jan 15, 2007 | 02:26 PM
steve05ram360's Avatar
steve05ram360
1st turn the key to the run position and listen for the fuel pump... no sound, dead pump. if the pump's working, then check for the fuel pressure at the fuel rail. should be 49 psi +/- 5psi. if that's good then check the crank position sensor and the coil. one of those is probably causing the problem.
Old Jan 15, 2007 | 02:32 PM
nateblong's Avatar
nateblong
ok im leaning towards crank sensor, pump runs, thanks guys ill let u know if I get a chance to work on it today...
Old Jan 15, 2007 | 02:34 PM
steve05ram360
you should still check the pressure... the pump could be running but not building up enough pressure.
Old Jan 15, 2007 | 02:40 PM
JarheadX's Avatar
JarheadX
i was just coming back to say that, but yeah, check the pressure
Old Jan 16, 2007 | 02:17 AM
nateblong's Avatar
nateblong
Had a buddy crank it while I tapped the coil. She fired right off. Thanks for your help gentlemen.
